I have a 1978 Mercury 1150/115 hp/L6cyl. Motor is extremely difficult to start when cold. In fact, it will not start without the use of starting fluid. I've had the carbs rebuilt, the fuel pump rebuilt, the timing checked, the compression checked and the spark checked. Everything has checked out OK, however, the cold start problem still persists. I was advised that the fuel/air mixture is not being drawn into the crankcase properly and that the reed valves probably need to be replaced. I'm wondering if my problem is with the reed valve, which is on the crankcase opening or the reeds within the reed blocks on the crankshaft (on three main bearings). Also, I understand the purpose of the reed valve, but I don't understand the purpose of the reeds within the reed blocks. Any advise is appreciated. Thanks
