Refitting lower unit Mariner 60-what grease is best for spline to stop binding up?
marineralec
Having finally got my lower unit off my Mariner 60 hp triple.To stop the drive shaft spline binding up again,what grease is best for this?I have copper grease,graphite grease,or regular automotive grease-the motor is used in salt water-will only use a small amount to avoid hydraulic issues-what do you guys use?
Faztbullet
Re: Refitting lower unit Mariner 60-what grease is best for spline to stop binding up
A good moly based grease with at least 60% molybdenum disulfide..
marineralec
Thanks for the heads up-I am sure I have got some kicking around somewhere
merc850
Mercury makes an anti-corrosion grease that will prevent the salt water corrosion and sticks like glue - here's a guide to keeping that motor free moving
marineralec
Thanks again you guys are great-what a fantastic forum
