DamianJP
Thread starter- Joined
- Mar 25, 2008
- 612
I usally anal enough to take pics when disassembling but I scewed up and forgot. Also have a manual but it is at a friends house. Its a E10SELCNS 9.9/15HP , has the 15HP carb, and I think it has the shims/exhaust to make it a 15HP.
Carb Kit: Float setup , What do you measure the float from and how to I take the measurement upside down or let it hang?
Fuel pump Kit: I think I have the right way, but while on the bench can someone shoot me a pic of the orientation of the gaskets/diaphrams. Also the kit has a big and smaller spring with plastic ends to sit on the diaphragm. I noticed who ever turned a wrench on the fuel pump kit the last used alittle grease to keep the springs/Plastic ends in place and not flying around while rebuilding/installing. Wasn't alot just enough for me to see and keep the springs and hardware from moving.
Can I use this method? Any hints ?
Water pump kit : Whats the torque on the pump housing bolts? And any hints/tips would be awesome !!!
Thanks,
DamianJP
Thanks,
DamianJP
