JoLin
- Joined
- Aug 18, 2007
- 5,146
I would expect marine fridges to adhere to the SAE marine standard for spark protection, like marine starters and alternators.
That's the question, and I can't find anything to support that opinion. I've had a few days to think about this, and here's my take...
1. NO QUESTION that anything residing in the bilge, or in an area where explosive vapors are likely to collect, must be intrinsically safe (spark protected). That includes engine ignition and electrical components, inverters, water heaters, etc., all of which are built to that 'marine' standard. I would not (and never have) use anything else.
2. The alcohol/electric cooktop in my cabin is an Origo marine unit that's in wide use on boats. The electric components are the same as you'd see in any other electric cooktop. Source wires plug into the rheostat and resistance coils using simple spade connectors. There's no vapor proofing or spark protection. The danger of using the alcohol burners is obvious, but I and thousands of others use them in both modes without incident.
3. My air conditioner was manufactured by Flagship Marine, which is also a major supplier to the USCG. No sealed circuit boards or other electrical components. Relays, transformer, capacitor, etc. are all off the shelf parts packed into a metal box and connected up with butt, ring and spade connectors. Not vapor proof or spark proof. The one electrical component that resides below the cabin sole and water line, is an intrinsically safe, marine-rated March circulating pump.
4. The 120-volt side of my Dometic marine refrigerator is fed by a power cord with a 3-prong plug, plugged into a wall receptacle, like the ones in your house. If you've ever removed an OE 'marine' microwave oven from a boat, they're connected the same way. They're also the same units used in RV's. I contend that the term 'marine rated' for these appliances refers to corrosion resistance and shock (as in g-force) protection.
5. Boaters (including most of you here) routinely use household microwave ovens, coffee makers, blenders, circulating fans and heaters (both electric and propane) in their cabins. Most of 'em came from WalMart
If I've missed something, please point it out. It's an important subject that we can all learn from.
