Refueling question
natsgrampy
Have an 89 Sea Ray I/O. I refuel the boat at a local gas station. My problem is it takes so long to fill. If I try to pump the gas faster it bubbles up and the fuel comes back out the filler hole.
Is there anything I can check to see why this happens, or, is this the way it goes with filling a boat fuel tank?
Re: Refueling question
Ayuh,.... My Guess is, the vent line is too close to the fill line on the tank, causin' yer issue,...
I donno of any Cure, other than pumpin' in slowly...
Silvertip
or the vent line is kinked or partially plugged by bug doo-doo.
airshot
On many boats it depends on where the tank is located. If tucked away in the floor the fill tube may have a long curvey travel to get there, and the more sharp bends it has the more fuel can back up in the line. The original tank in my Islander was a pain to fill, when the boat was refreshed the original steel tank was replaced with an alum tank and repositioned to give a straighter run for the fill tube. It now fills much faster than before, but still not as fast as a car due to the longer run for the fill tube. Many autos have a larger fill tubes as they are a direct route to the tank, whereas a boat uses a smaller dia tube to squeeze thru the cramped confines of interior walls. Hope this gives you some sort of explanation.
Airshot
natsgrampy
Thanks, I will check the vent line for blockage or kinks. It is in the floor so I may just have to fill it slowly.
truckermatt
My 25 gallon tank in floor does the same thing..
I just take my time and listen for the gurlgle, then i know when to stop... Otherwise it comes out the fill tube.
