Regular LCD Tv or Marine Tv?
CrazyBoy
Hi!
I was thinking of buying a 15" LCD for my boat, guess just for the kick of it. I have a 21' boat and was wondering if a regular LCD Tv which is half the price would do versus a marine Tv.
Thx!
Lion hunter
Re: Regular LCD Tv or Marine Tv?
Don't know that they would handle the constant vibration that a marine tv is designed to do.
CrazyBoy
True, didn't think of the vibrations..
smokeonthewater
any 12 volt tv you get will be designed to be mobile.... fwiw I have 32" and 47" 110 volt lcd's in my rv and they have held up fine so far...... Your biggest concern is water..... if it will be above deck then it needs to be weather proof
lakegeorge
We have had several regular tv's over the years on our boats and never had a problem.
CrazyBoy
Well, i found the coby 15" with DVD combo for $180, it's 110v but I have a 12v adapter and it's going in the cabing, so thought I'd get the non marine version and save over $220
Does this make sense?
Thx
RollingWanderer
Typically the "advantage" of the rv or marine specific tv is that it will run off of 12v. With that being said, I have used standard lcd tv's and display panels in a lot of mobile setups and have never had any problems. Just keep it dry.
-RW
smokeonthewater
I would strongly recomend a 12v tv.. The inverter to run the 110v will use alot more battery
