rickdb1boat
- Joined
- Jan 23, 2002
- 11,195
Are all motors with just rectifiers, as opposed to regulator/rectifiers, unregulated charging systems? Such as my 91' 70 rude??
Mark,<br /><br /><br />What do you mean with break-up? If you're just in the water with the boat, and you can't reach higher then 5700 rpm, that might be because the engine/boat combination, the prop, the setup of the outboard and the load in the boat, doesn't permit more rpm's at WOT. In you're case it looks fine. <br />The rev. limiter has a different purpose. It prevents damage on your engine caused by f.i. a runaway condition while running on muffs (not on a load), blowout/ventilation of your prop while boating, that kind of things.<br /><br />EDIT: (sorry, saw later I rementioned some things rickdb1boat said earlier)Originally posted by Mark42:<br /> Thanks Seahorse and Rick,<br /><br />The OMC manual indicates 6p, so I will stay with that for now. It is the rpm limit in the power pack spec that is throwing me off. OMC says 6700 rpm, but I break up at 5700 or 5800. So I thought something is wrong.<br /><br />And what is wrong with the wing nuts? Not a good enough contact for the higher amperage charge?<br /><br />Mark.
