juicebronco
Thread starter- Joined
- Jun 17, 2011
- 67
85 Century Palomino
170hp 3.7L Mercruiser
After doing some reading I figured my Regulator Rectifier was shot, I am generally only pulling 11V and some change while the motor is running at idle, underload over 1K rpm, and no load 1K rpm. I tested it with a meter as well at the batery and also only pulled ~11.3V. So while deciding if I was going with the alternator kit, or a new reg/rec I've been taking the boat out with fully charged batteies and running it. Last night, for a while I was pulling 12.2-12.4V according to both my fishfinder and my dash guage. It wasn't due to the fresh charge on the batteries, because when I first launched, it was only in the low 11s, but I went for a cruise part way through the night and it was kicking out a full volt more, even at idle.
I feel like I should be closer to 13 correct?
But what would cause the jump in a full vlot? Is it possible that I could take apart the connections clean it up and it would work? Everything looks clean, but you never know.
I'm just looking for some input on things that could be causing issues that would simmulate a bad reg/rec that I could go through and check out prior to spending the cash for replacement.
any input would be great, Thanks!
