fishfeatures
Thread starter- Joined
- Mar 29, 2011
- 743
I swopped out the rectifier on my 1990 60hp johnson for a regulator from a 2000 60hp evinrude. The reason being is that it was concluded that the rectifier r was charging the battery too high and it was this high charge that blew the internals on all my gauges (approx 16v)
Now i've hooked up the regulator and am still not getting a charge, what do i need to test to check that the regulator is working ok or not?
if that proves unsuccessful i will then move on and test the stator.
All connections have been checked and are clean and tight all the way from the battery to the regulator.
