Baylinerchuck
- Joined
- Jul 29, 2016
- 2,737
Oh my goodness….. please don’t compatible the boat….. she’s far too pretty for that!!!Hey thanks Chuck. I'll be making a compost unit very soon.
Thanks for posting this. I recently learned what PB stands for and what products are required to make it. What does PL stand for? I (like many others) are trying to learn the lingo so I can understand process.As well as this,
Stringers-Updated 03/11/2014
Epoxy Resin
If you choose to use Epoxy for your Stringers, then you'll only need to use Fabric or Cloth to cover them.
2 layers of 17oz cloth will be adequate. The drawing is basically the same just won't use CSM or 1708. Layup will be a bit more difficult due to the fact that Epoxy cures at a much slower rate than Poly and is a bit more "Runny" so it will have a tendency to want to run off the side of the stringer and Pool at the bottom. You'll need to Babysit it and keep pulling it back up onto the surface of the cloth until it begins to tack up a bit.
Polyester Resin
PL is basically PB in a tube.Thanks for posting this. I recently learned what PB stands for and what products are required to make it. What does PL stand for? I (like many others) are trying to learn the lingo so I can understand process.
Like Kevin stated, PL is a glue. It’s made by Loctite and is called Pro-Line polyurethane construction adhesive. It’s a really good glue but has some draw backs as mentioned such as gassing off and making bubbles if applied too thick. I used it when glueing wood pieces together like sections of the transom, laminating plywood to build thickness, etc. When bonding plywood to fiberglass I use PB exclusively. Adding milled fibers to PB will make it much stronger than PL. Link to Loctite PL below.Thanks for posting this. I recently learned what PB stands for and what products are required to make it. What does PL stand for? I (like many others) are trying to learn the lingo so I can understand process.
If u were up here Micky, we could just go finish it for himjuyst poppin in to see where ya aree, havent worked on mine all year eyes cant handle sunlight ... i might get out there though if it looks like you gonna splash in a couple months![]()
So PL is different than PL400 the construction adhesive?PL is basically PB in a tube.
It can be used in many marine applications same as pb. Their is a wide variety of mfg's and they can all have different adhesion, drying and water qualities So make sure you use the right pl for the right application.PL Premium
www.simplicityboats.com
I prefer making my own PB in leu of PL simply because I have it on site. you can make it thick enough to do upside down work.
A draw back for me with PL is that after applied it needs hours or days to gas off. If you glass over it right after applying your glass blows up with bubbles.
There are many "PL" types out there. Specifically for marine use is:So PL is different than PL400 the construction adhesive?
I’m not that far from there and would certainly help drink beer……er I mean launch a boat.If u were up here Micky, we could just go finish it for him![]()
Yea I'm gonna do a little more research, check with marine engine etc. See what they say. I'm sure there is something I can swap out though prices are high. Worst to me scenario is I'll use the ole girl, polish it up and mount it.Wish I could help you. Both of my Johnson’s came with the side mount control. Possibly look around for a center console salvage?
New top mount Johnson with integrated key is about $175 on ebayCompleted 2 more windows with the sikaflex edging. Yea....
messy stuff for sure.
Here's a question for the sages. The johnson 225 VRO/86 came with a side mount controller and harness. The boat had a console style unit/no harness. I would like to use a console replacement. The current unit is a mess and not worth a redo.
I would also like an integral key sart vs. seperate.
Anyone have any ideas as of what I could use?
Thanks guys.
Side mount;
Console unit;
I've seen them Larry but they all add a clause like "2003" motor compatible.
i didnt see anything about 2003, but did see 1997 and up on one review, but its mechanical, not electric shift, so maybe just the key and trim wire connectors are used for compatibility.....I've seen them Larry but they all add a clause like "2003" motor compatible.
