kcassells
- Joined
- Oct 16, 2012
- 8,743
Here's a cool wood boat bldr, rehabber. Boats look real sweet.
https://www.firstlightboatworks.com/#intro
Keeping the site alive till warmer weather. Been working on my little project and nailed it!
This underdeck compartment simulation is all soaked ply and fiber glassed.
https://youtu.be/1V4zTGILcUo
Says video unavailable here
Looks like the water is all draining out nicely now Kev!.....
BTW, who's the dork you found to narrate that vid?![]()
Come summer I'll have to get a small boat and demonstrate all compartments linked together.
Hi Kev, the video looks really good, you had all water out that for sure and with the boat moving due to gravity you will defiantly get 99.9% out. The only troubled thing is how wet is the foam after water is drained out and with the compartment sealed how this foam will dry out to prevent the moisture to compromise the fiberglass. If like in your case, epoxy is used that doesn’t create that much a problem, but with poly that could be another story. Just my thinking.
I have a boat laying around for a demo .. You’ll need to do some grinding before you install the new stringers and transom though .. Don’t worry I have some tools you can borrow to knock it out ...
Seems to be draining well ! You may be on to something !
