Rehab SportCraft 222 1983 deep V hull cuddy walkaround
kcassells
So stuck in the rest of the plywood deck with pb/1/4" glass/steroids.
Moved to the stern and started installing www.flotationfoamsolutions.com components and happy with it.
Seems like oh it'll take an hour that turns into 4-8 hours. Do Love that hairy PB,
Also ran plastic hose/vacuum pcs. for future runs of electric and bilge water. Beat. Have a nicey day!
2018_0325_070353_001.JPG2018_0325_070405_002.JPG2018_0325_070415_003.JPG2018_0325_071043_001.JPG2018_0325_071315_001.JPG2018_0325_071329_003.JPG
kcassells
So the Rustoleum formula Woodonglass cleaned up nice considering all the seasons and abuse with mild soapy water.
Click image for larger version  Name:	2018_0325_071315_001.JPG Views:	2 Size:	765.4 KB ID:	10718439Click image for larger version  Name:	2018_0325_071329_003.JPG Views:	2 Size:	443.3 KB ID:	10718440Click image for larger version  Name:	2018_0325_080350_002.JPG Views:	1 Size:	544.8 KB ID:	10718441Click image for larger version  Name:	2018_0325_080403_004.JPG Views:	1 Size:	505.0 KB ID:	10718442Click image for larger version  Name:	2018_0325_082352_001.JPG Views:	1 Size:	730.9 KB ID:	10718443
I think Russians own USComp…..ites
kcassells
What prompted not using pourable foam?
No....that definitely goes in next. This is the only system www.flotationfoamsolutions.com lets each underdeck compartment flow to the next compartment till it gets to the bilge. No mechanical devices required. Alas the poured foam does not get compromised and hold water.
I'm keeping this boat and this is how not to care about trapped water underdeck...……...the killer.
kcassells
The concept is yes flotation foam with a way to let it drain and aerate front to back. 24/7
Ciera2450
So the pourable foam will go over top? And adhere to the foamsolutions stuff? Interesting... I don’t think I e ever seen it. Granted, I don’t have any foam in my barge.
just checked out their website. Great idea
kcassells
Yup...……...just like that. No you will never see it again. Tried true and tested. Albeit not " by a million dollar company" entry . You should foam your boat. CG requires foam for under 20' boats. ABCY says 30' boats.
Radder float dan sink. It's just too easy. Plus the compartments aerate....OMG?
Ciera2450
I’m 26’... didn’t have any foam and didn’t put any back. It’d take a crap ton of foam to do any good on a 6k lb boat. I dunno even where I’d put it.
kcassells
Thanks Eric,
Having fun bending and kneeling. Even picked up knee pads. Ha ha no funnies.
I'm getting SAM Back, couple Advil and libations per my doc. Fitting back the fish wells, they were snug to begin with so a trim here and a trim there seems to be working.
Got some rain and guess what saw water flow to my bilge. That was cool. :D
oldrem
Thanks Eric,
I learned to use knee pads about 20 years ago - really help to save the legs and back. Amazing what a difference they make.
kcassells
So the rain hasn't stopped and temp is holding @ 50 deg. Plenty to do though and figure out approach. Refit fish wells and puzzle pc. between transom deck and main deck. It's coming together nicely. Lots of grinding and fairing coming up before I throw down some glass.
2018_0326_060417_001.JPG2018_0326_060423_002.JPG2018_0326_060428_003.JPG2018_0326_060450_004.JPG2018_0326_060458_005.JPG2018_0326_060504_006.JPG
kcassells
Anyone else getting this off of us comp website?
[h=2]This site is not secure[/h] This might mean that someone’s trying to fool you or steal any info you send to the server. You should close this site immediately.
Go to your Start page
Details
This website’s security certificate has been revoked, so you can’t go there at this time.
Error Code: ERROR_INTERNET_SEC_CERT_REVOKED
Ciera2450
I have seen that clone site before. I usually type their address directly into the browser and it goes to the right place
kcassells
freakin Russians! Thanks I'll try that.
No luck with that when I go to order that popup shows. Man I need to order some fumed silica.
kcassells
I was able to send of an em off to them. I will call tom. and make verbal order, forgot about that option. Thanks guys.
