Rehab SportCraft 222 1983 deep V hull cuddy walkaround
kcassells
Kinda like this pic!
Nothing better than a good set of shoulder pads
mickyryan
well looks like ya moving along! never let weather muck up a good days work i say :)
zool
Hmm, I was expecting a progress update Kev.....No problem, just eat, crash on the couch, and enjoy yourself..
Merry Christmas Man!
kcassells
Nahh.. been doing the Christmas shuffle last couple of weeks. I'll regroup shortly. Man I hate this weather.
zool
Same here, kinda glad its past...these temps are just too risky for critical lams, best to sit it out a bit, next week looks to get us back in the 40's....thats doable........
Sitting by the FP with glass of wine feels "sensible" to me right now :D Cheers!
oldrem
What I'd give for even 20's right now. Had a high of 6 today and -5 tonight. Our temps are running 25 deg below normal and not expected to get above freezing until Jan 7th
kcassells
I'm with on that , fireplace, wine.....Sorry to hear those temps Rem.
kcassells
Kev,
Always remember Any Progress Is GREAT Progress!!!
Thanks Mike! Through the tenure of this project I have kept the line in my head. ;)
Especially with all your support and the guys here that are too many to mention.........yes zool that means you.
Just started to giggle at myself with that line. :D
kcassells
Wow got temps up to 50 today and tomorrow. Still holing up in my cave though. Been thinkinking about the wheelhouse build.
There are soooooo many options out there for materials and each one sure does have a crazy price tag to it as you do comparisons.
Composites, foams, balsa, ply etc. and ea. has it's own characteristics. AAhhh
Just looking into opions. Fact is that it's all about cost. So that will probably eliminate the high end poop although I would like to use it. Probably going this way for the wheelhouse with marine grade end balsa sheets. Seems to have come along way, it lighter than ply, has a built in sealant and conforms to shaping.
Opinions welcomed.
characteristics [h=2]Product description[/h]
Coated End-Grain Balsa Wood Core: BALSASUD Core. Dimensions are 24" W x 48" L. Density is 9.5 Lbs. per Cubic Foot. Our UV-coated end-grain balsa wood core material has remarkable physical properties, starting with its outstanding strength-to-weight ratios (high shear and compression strength). This advanced epoxy-based coating is the latest technology and enables better bonding adhesion and reduces resin absorption. Our balsa wood has been kiln-dried to perfection. Additionally, this structural balsa wood core material is easy to bond when using any type of resin or adhesive. Balsa core also serves as a natural insulator, fire retardant and noise reduction material. Working with balsa wood is easy, as it can handle changes in temperature and is highly chemical resistant (including styrene). All these advantages make CoreLite's balsa wood an ideal core material in sandwich construction. Balsa wood is also an all-natural product and a renewable resource, coming 100% from Ecuador. Our BALSASUD Core is of truly remarkable quality. Getting the materials from CoreLite is as direct to the raw source as you can get: we sustainably grow our own trees and manufacture the balsa core in our state-of-the-art facilities. Learn more at: www.corelitecomposites.com
Woodonglass
It's been my experience and that of others that Balsa Core is NOT the easiest material to work with.
sphelps
The corelite boards sound interesting .. Is this for epoxy application only or will poly stick ?
At some point I need to make a casting deck for the Manatee ..
Come on spring !!!
