Rehab SportCraft 222 1983 deep V hull cuddy walkaround
kcassells
Probably Escargot @zool
Got to stay home today. Freakin right knee in the middle of a blow out. See doc later, drain and shot. I hope thats all.
Anyway played with joining some teak up. Used dowels on 45 deg cuts and glued with EEEpppoooxxyy. Letting it set up.
I have join 1 more pc. to each, trim to fit then apply port and starboard.
zool
You should check with Kirby paint regarding letting teak cleaners get on the painted surface...I was reading the Awlcraft sheet and it mentioned no use of teak cleaner to get in contact with the their topcoats.
kcassells
Good point Larry and thank you. When I get to that point I'll tape it off but will def. look at the link kirby has in that regards. I drink most of the future will be a light sanding and re-oil no cleaners.
Thanks again, appreciated!!
kcassells
Only you could find that cartoon.. Hats off Sir Zool. LMAO
AShipShow
I'm gonna need to attend the kcasssells school o' eeeeeeeeeeeeeepoxy here pretty soon... I have a couple little projects for the dirty rotten baystard that I wanna get checked off the list and I'm sick of poly resin going bad so I decided to buy a gallon of totalboat 2:1 epoxy for my last few projects... Gonna be a new learnin' sperience for me
kcassells
You go for it!
kcassells
I think once you see how stupid dumb EEEpppoxxxy is you will never go back. :}
kcassells
Worked a little more on the teak. Jined up the 2 pcs with a 45 cut. Roughed up and wetted out with acetone, applied epoxxxxyyy. Today I added the top pc. same procedure. I will make a template of where it goes and cut to fit. From there work edges etc to the final. Need to do the same for the other side. I might add some glass to the back side of the teak where the joints are. Up for debat.
Crazy heat and weird storms here. All good.
Funny though now starting Mon. we have to wear masks at work again for the new variant. WTPOOP.
Sloooowly getting back to the bilge pumps and electrical.
AShipShow
Yeah, my street/strip car is the real money suck. 🥵 ...and my wife and daughter don't really get to enjoy it. Of course they haven't gotten to enjoy the boat yet either. 😂
Thats the key... you don't do stuff TOO fast, cuz you build up the anticipation of all the fun they will have once its done, then they have a blast once its complete... Then after a season or two goes buy, you sell the boat and then they miss it so much they want you to get a boat again, and then you buy a bigger boat...
Rinse and repeat until you end up with a huge yacht :ROFLMAO:
kcassells
Bigger Better Hmmmm
sphelps
Yeah , we got put back on mask at work too .. Even if you've been vaccinated .. Try getting 100 Hispanics to keep there mask on in this Fl humidity ..
KC , ifin you varnish over the epoxy let it cure a good while and make sure you scrub the crap out of it with soap and water before you varnish .. Amish Blush is a sob ...
kcassells
Thanks for the info Sam. Were finding people at work with the "TRUST" factor not wearing any masks. Seems like were heading backwards. Anyway good to hear from you.
kcassells
Man o Man I butched up the teak yesterday for cut to fit with template.
So PO so thar it is. No pics cause I'm scrambling to figga out how not to spend another 200 potatoes.
Don't tell anyone Sam......Ahhhh!
