reinforcing transom
joho5
i have a 14' Jon boat that I pulled the transom the other day to reinforce / replace the wood. My transon would actually flex when the motor was throttled, which then would affect the trim of the motor.
So, I decided to replace it and try to possibly reinforce it a bit. First off, the previous owner had that chip, cheap board as the transon and it wasnt bolted that good or even.
I was just going to actually buy some good plywood and replace the wood and distribute the bolts equally and that should do wonders, but I was wondering if there is anything else you guys have done in the past to reinforce it to make it more stable.
or, is there a way to make a fully aluminum transom by welding?
Bob_VT
Re: reinforcing transom
A few things.
How much power?
Does it have knee braces? How about corner braces?
All aluminum would be a waste of good money. The wood will work fine and last quite a long time.
I think to have this best answered we should move this to the restoration section.
5150abf
Even with new wood your transom will flex a bit, you really don't want it not to, it helps to distribute the force of the motor.
You have to be really careful welding on aluminum, espacially something thin like a jon boat, welds tend to crack along the edge especially when they are constantly being loaded and unloaded as in a transom.( have welded alum. for 21 years)
On a 14' jon I can't imagiine you have a huge engine so I think just replacing the wood will do fine.
Use exterior grade 3/4'' plywood, cut 2 peices to shape and glue them together with Gorilla glue or something similar.
Mount the new transom and drill all your hole then pull it and put a good waterproofer on the entire thing, especially the holes and edges, bolt it in and you are good for years.
Good luck.
sschefer
Good luck.
That's great advice, the only thing I might add is a commonly made mistake. Don't run the transom all the way to the bottom of the boat. Leave it about 1-1/2 inches from the bottom. This will prevent it from wicking up water should your sealing method fail.
oops!
as mentioned, pics would help a lot.
you say the transom "flexes" with the motor on.......the question is, how much ;).
all the above advise is good. knees and corner caps on a normally sound peice of alumunum are all that would be normally done.....anything else would be over kill.
oops!
A few things.
How much power?
hey bob.......nice to see you down here in dry dock :D
