Reinstall of platform ladder
abishoff
Over the winter, I removed my platform ladder because it was causing a tear in my water proof cover. Now, i am unable to access an area of the underside of the platform as its full of hard foam. Can i cut the foam out to access that area and hold the nuts to re-attached the ladder with the thru-bolts and nuts? Its a 2001 Stingray 190LS runabout
Not seeing what your seeing I'll say this. Removing a little foam should not cause any concern
JASinIL2006
You should be able to remove the foam without problem. Just be sure to seal any thru-hull holes with a good sealant like 3M 4200 or 5200.
