buckmowens
Thread starter- Joined
- Oct 5, 2007
- 5
Can anyone help me? I have replaced a propshaft and installed an impeller repair kit on an 1975 Evinrude 85hp V4 lower unit that is manual shift with hydrolic assist. Everything went fine with no problems, until reinstalling the lower unit to the motor. Everything is lining up just fine. With the unit in reverse gear as described by the sevice manual I can get the lower unit up to the last 1/4 inch. I can feel the drive shaft hit the crankshaft and with a little turn of the prop I can get the two to mesh together smoothly. From what I can see there is nothing else holding it up. The shift rod is not bound up either. I'm at the point of torqing down the bolts, but afraid of damaging anthing after all the work.
