reinstalling Merc Lower unit
Steven D
Re: reinstalling Merc Lower unit
Check me if I'm wrong here, but pulling the drive doesn't change the alignment just gives you a chance to check it?
ziggy
that's true. and if it has changed and is out of alignment. you need to find out why... + it gives ya a chance to do other required pm...
CheapboatKev
I gotta tell ya..
Even though I dont have the lower & upper all back together yet..
By taking the upper off I did find the water inlet packed with sand and muck.
I flushed it out had I not taken it off, I would prob burn up this new impeller that I have been fighting with.
wvmedic
Good thing you took it apart, now you will at least have peace of mind.
Jeff.
CheapboatKev
Just to close this and say THANK YOU GUYS for the sound advice.
Turning the shaft a 1/4 turn let her drop right on (since I had it upside down).
She's all together, back on the boat filled with fresh OD lube..
What is funny, is that I filled from the bottom as everything I have read says to..Yet at the top port side of the upper unit, the screw there says OIL FILL....Regardless...she'll be fired up tomorrow night with the temp gauge hooked up and hopefully no heat issues this weekend on the water..
This is a great PDF that Jim sent me via a PM as well...
http://www.boatfix.com/merc/Servmanl/6/6C3R3.PDF
bigskiohio
so upside down on bench is the way to go?
CheapboatKev
That worked for me..
Although I need to start a new post as my shifting has gone to heck in a handbasket:mad:
