I pulled my OMC Cobra engine, and was able to do so fairly easily without pulling my outdrive. This is my first time, so I'm looking for experienced advice here.<br /><br />Everything I have read so far indicates that if I pull the outdrive, I need to use the alignment tool to align the drive and engine.<br /><br />My question is, if I get the engine back in without pulling the outdrive, should I still pull the outdrive and do the alignment??<br /><br />I am not moving the engine mounts at all.. I am replacing the engine (cracked block).<br /><br />Thanks
