Thanks to everyone for your suggestions. I got it in, but now no reverse. I had it all the way forward for the remove an install, and forward and neutral are fine, but no reverse. With it tilted up, I can see the shifter lever turn when it is shifted into reverse, but the prop still spins freely. Any idea what went wrong? Do I need to pull it and try again? Reverse worked before removal.[/QUOT
take your shift cable loose and make sure you can move it all the way in by hand easily, then all the way out it should move freely, if not change your shift cable, if it does adjust your cable by the book and it should work fine
