Still having problems with TnT orig problem was up not working down ok, bought a new relay for the TnT up position replaced it
still not working so I swapped top to bottom ,bottom to top now it will go up but not down. Is this a case that possible both relays need to be replaced as a unit? I have ruled out the possiblablity that the plug its self is bad by swapping out the relays I swapped them several times to duplicate the situation and same results. This is on a 1991 Evenrude 40hp
Thanks in advance
Tom H
Thanks in advance
Tom H
