Releasing Trim N Tilt
tashasdaddy
your T N T is not working, you need to move motor.
on newer motors, On the port side of the bracket, should be an oval hole, look inside. older motors some are on the starboard side.
there should be a machine screw with a circlip to prevent it backing out completely.
Use an impact screwdriver to loosen if needed, or a square shaft screwdriver with a wide blade and put a wrench on the shaft, its really in there good,
back it out to the circlip and then lift the leg, takes a bit of pressure to get it moving but once it starts keep going and have something ready to slide under it like a sawhorse.
Tighten it the same way, put a wrench to it, 45lbs torque.
