Re: Reliable Sure Lube Axle
I've had the Sure Lube axles under my boat trailers for 11 years, towed more than 20,000 miles.....and have never repacked a wheel bearing. I'll give the hub a few shots of grease every few months and before/during a long trip.
If you don't pump a little grease into them every once in awhile, the grease discharge hole on the backside of the torsion arm can become blocked with a hardened grease plug. If the grease hardens, then it is possible to pop/blow the rear grease seal when pumping in new grease.
