Relocated the Bilge Pump
tpenfield
Since I have been going through my 'new-to-me' boat and getting everything ready for launching in May, I decided to relocate the bilge pump.
The thing about bilge pumps is that they are typically located at the furthest point from where the water is . . . which in a power boat is near the transom. I'm sure that the manufacturers locate the pumps in a convenient location, up near the bulkhead, where they can be serviced, etc. However, the best place for a bilge pump is near the transom where water levels are deeper and the water accumulates when coming on plane.
So, I decided to relocate the bilge pump to a location near the transom. In order to do this, I figured that I needed to fabricate a 'carrier' of some sort to hold the pump and float switch. This 'carrier' would allow the pump and float switch to be pulled out for servicing needs, etc.
I had a few failed attempts at some designs for the 'carrier', but finally came up with a re-engineered design . . .
This design would put the bilge pump near the transom and the float switch just forward of it. The carrier is contoured to fit the ribs in the hull so that the float switch and pump can sit fairly low in the bilge. I scrounged up some material to fabricate the carrier and cut out the parts . . .
Then I fastened everything together . . .
I made the float switch level and facing across the boat, so that the inclination of the hull would not falsely activate the pump. I made the bilge pump set at an angle to match the shape of the V-hull, which allowed it to be slightly lower than the float switch. This would ensure that the pump will not suck air or any other adverse effects.
Then it was a matter of test fitting the carrier and components in the bilge.
- - - continued on next post - - -
tpenfield
Re: Relocated the Bilge Pump
Here is a picture of test fitting of the carrier in the back of the bilge . . . looks OK.
Then I fastened all the components, wiring, etc to the carrier . . .
The carrier is designed to slide back under the port engine and then is fastened into place. If maintenance is needed for the pump and/or switch, I can easily pull everything back out for good access.
Here are the carrier and components installed in their intended location . . . The pump is right along the keel about 1" forward of the transom . . .
Now it was time to test the thing . . . I left a garden hose running into the bilge and checked to see that the bilge pump cycled properly.
OMG, it actually works :thumb:
I let it go for about four cycles, seems to be fine. If I really want to clear out the bilge I can switch the pump 'on' while coming up on plane, as all the water will be back at the transom.
I'm glad that project is done . . . it took a lot longer than I had expected . . . :rolleyes:
Blujay96
Looks good. I like the cad work for the planning. I do the same thing
64osby
Very nice, great detail. I have a back up pump soon to be installed and your write up is inspiring ideas, thanks.:joyous:
airshot
Just a thought here, on my boat I decided to install two pumps, one running off of each battery, you just never know!! I guess it brings me piece of mind as I have had a pump go bad before.
Airshot
crabby captain john
When chartering on Lake Erie I had 3 pumps to individual batteries. now with a smaller - 21' - boat I only have 2. never but never rely on one!
Airshot
tpenfield
I should put in a secondary pump and probably connected to the second battery . . . perhaps I can put that up near the bulkhead where the pump was originally.
littlerayray
awesome idea and design makes me wonder why it wasnt made or thought of before
