Remanufactured Carb recommendations
matt167
Sounds like a coil going south..
The carb is 'just' a Rochester that has some marine modifications. A hotrod shop or other person familiar with Rochester carbs would be able to rebuild/ adjust it. They are not a special carb
muskrat808
So- Is there a way to test coil or just go ahead and replace ( Sierra or OEM ) ? Thanks
fishrdan
If it's the coil getting heat soaked and causing issues, run it until it acts up again, then cool the coil rapidly (big chunk of ice held on the coil side for 5+- min, then see if it runs good again for a period of time until the coil heats up again. You could also test the coil with an ohm meter, cold, then when the engine is having problem. (I don't have the resistance measurements off hand...)
Being a 72', if you haven't changed points and condenser, I'd do that also.
If you're going to dump a bunch of money into the ignition, look at Delco EST for the 140HP/Merceuiser 3.0L
