pontoon chief
Thread starter- Joined
- Aug 9, 2004
- 116
I am working on a 2001 OX225 that had overheated recently.
After unseizing the motor I found that the remote oil tank had been run dry and the motor had overheated due to lack of oil,not a water problem as I had been informed.
Since I had the boat apart I removed the remote tank and found the small inline filter blocked to the point of almost no oil being pumped up the line to the engine tank.The pump works fine now and pumps a fair amount of oil from the remote tank to the motor.
While testing the system I found that the system work fine when the key is turned on and the system is calling for oil.The pump will turn on and punp the motor tank full to the top line in the motor tank.With the key still on I can drain the motor tank and the oil level will drop to the point where the pump should turn on,but it does not.Shortly after the alarm will sound and the tank will continue to drain until it is completely empty.While doing so the alarm will continue to sound.
After I turn the key off and than back on,the pump will again pump the motor tank full.
I changed the motor tank oil sensor and this did not correct the problem.
The emergency bypass toggle switch located to the left of the motor tank works correctly,and will pump the motor tank full if I hold the toggle switch up long enough.
I can not understand why the pump will not turn on when the sensor should be calling for oil,to include the alarm being on.
Any body ever go through this issue?
Patrick
Patrick
