Remove and install OMC GM 305 carb
jigeye
Assuming you have the genuine OMC manual, how hard is it to
1. Take out the engine
2. Put in a remanufactured engine
Any special tools needed?
How long does it take for step 1 and 2?
Does outdrive have to come off boat for 1?
Howard Sterndrive
Re: Remove and install OMC GM 305 carb
need to know the year and drive type, as it is a different process for different OMC drives
how long something takes someone is pretty subjective
what is your "remanufactured engine"- long block? completely dressed? short block?
the answer to that can add or subtract 3 to 5 hours and will determine what special tools are required (e.g. timing light)
