Joker757
Thread starter- Joined
- May 13, 2009
- 134
I've started to remove the bottom paint on my 1999 Maxum 2800SCR. I started out with Aquastrip which works ok however due to the many layers of paint requires two applications, is very messy and expensive. My neighbor did his Trophy last year and said he used a 4000psi pressure washer with a sandblasting attachment and the finest sand he could find. He said that the water helped cut down the agressiveness and it turned out fine. He cautioned not to try to go all the way down to the gelcoat but however get down close two where a signle pass with a DA and 80 grit would do the rest. I've searched the forums here however wasn't able to find much mentioned about the method. Does anyone here have any experience with this method? If so any feedback would be greatly appreciated. I'm taking all the necessary safety precautions. I have a full face respirator (3M 7800) and other necessary items to ensure that none of it is inhaled or comes in contact with my skin. I trailer the boat and plan to coat with Interprotect 2000 and VC Epoxy.
Thanks.
Thanks.
