I'm in the process of replacing the wood, vinyl, and carpet in my 92 Searay BR200. In the process, i've found a small soft spot under the port side bucket seat.<br /><br />I've read many of the posts here with regard to cutting out the floor and checking for additional rot, etc.<br /><br />My question is...do I need to drain or even remove my gas tank before i begin to cut out this small soft spot in the floor to determine if I have additional rot there.<br /><br />My tank appears to be in very good shape and is in the floor with a covered access panel.<br /><br />Thanks,<br /><br />Jeff
