??Remove Oil Warning??
BassFish
I have recently switched from oil injection to pre-mix on a 1995 Merc 150hp XRI EFI. I didn't want to make the switch but the plastic gear inside the block was stripped so this was a cheaper option. I am now wondering if I can remove the oil warning module to stop the alarm? The module is also connected to the 'water in the fuel' sensor module. Will the removal of the oil module affect any other sensors?
Thanks
