Removed raw water pump - rotated harmonic balancer…now what?
Ddmunden
I had a leaking water pump so I removed the impeller casing and when I went to remove the three bolts holding the water pump onto the harmonic balancer, the whole thing rotated slightly counter clockwise. Not sure where the initial position was. Do I need to realign the harmonic balanced before installing the new water pump, and if so, how? or does it not matter that it moved during removal? Any help is appreciated. Thanks!
dubs283
Shouldn't matter. But you may need to clock the pump assy once installed to line up the support arm from the block
Ddmunden
Thanks. I am assuming The impeller housing should rotate easily back into the position needed to get the support arm lined up regardless of where the pulley and harmonic balancer are positioned. I was just concerned that I may have screwed up the timing some how by accidentally rotating the balancer during water pump removal.
Scott06
Balancer is keyed to crankshaft and needs a puller to remove
Ddmunden
The balancer doesn't need to be removed, it just turned counter clockwise slightly when I removed the water pump, meaning the crankshaft itself turned inside the engine. I was just concerned that the balancer would need to be rotated back to its original position before I install the new water pump to avoid messing up the timing, etc. But I wasn't sure where that "initial" position was.
itsathepete
The harmonic balancer turns at the same speed as the engine. Doesn't matter that you turned it as long as you can get the pump mounted properly
Ddmunden
Appreciate all the comments! I'll go ahead and mount the new pump to the balancer and fire it up! Thanks again.
- David
