Removing a hull # written in permanent marker
bambam634
I bought an older aluminium jon boat that needs a new Hull # and i was wondering what every one uses to remove the marker
I dont want to sand it off
any help would be great
thanks
airdvr1227
Re: Removing a hull # written in permanent marker
Can you just cover over it with the new number?
bambam634
Oh no the guy who did it must have been blind... the numbers stretch almost 2 foot long by about 8" high
GT1000000
What are the numbers made with? Paint or Vinyl?
If paint, you can use some stripper, Acetone or lacquer thinner...
If vinyl you can use an eraser wheel on a drill motor...
If the surface underneath is painted, whatever you use may damage the paint...
Woodonglass
Try some Xylol (Xylene). Get it at Lowe's. Wear a mask it's nasty stuff
th
xanthras
Try going over it with a dry erase marker. then wipe it off. No I am not kidding. Try it out.
matt167
If it is indeliable ink ( Sharpie ) than Isopropyl Alcohol will take it off
calvinator
If it is a Sharpie marker, use denatured alcohol. Sharpie ink is alcohol based and will dissolve with denatured alcohol. Denatured alcohol is not strong and won't hurt your paint, gelcoat, or alum. either
bambam634
Its in permanent marker...
looks like i have a couple things to try out.. we have some Isopropyl Alcohol at home i will try first if that doesn't work next time im in town i will pick up another item suggested
thanks again
jbcurt00
Isopropyl Alcohol comes in multiple strengths:
Try what you have at home, then go higher % if it doesn't quite take it off......
colbyt
Master Chief Petty Officer
And the good news is that Wal-Mart carries all 3. There will be a large display of the weak stuff and then over in an obscure shelf space you will find the 90% for about $3 per bottle. That is less than half what you will pay at the paint store.
bambam634
sorry so late to respond
I tried the dry erase marker, rubbing alchol 99%and a menards paint thinner.. all with no luck. So as we were getting frustrated I found an old can of Wooley paint thinner in my dads barn so as a last resort we applied it on with a rag .. and off came the numbers. it was almost like a model car paint that they had used..
So thanks again for all the help
matt167
probably a paint pen. It's basically model paint, but looks just like magic marker if it's applied thin enough
Woodonglass
But you didn't try Xylene did you??
bambam634
No sir we did not that was the next thing we were going to try
