removing a lower cowling...
js361
can anyone tell me how to do this on a 90hp 1995 johnson? I'm trty to replace the thermostats.<br />Appreciate the help
Walker
Re: removing a lower cowling...
Should be 4 bolts holding it together. Look on the rear through the clamps, down lower under the pan, on the front through the clamp and another in front right in front of the mid-section. And then there will be a spring clip on the alignment studs inside the pan on each side. Just pull the clips off.
js361
ok sounds easy enought....thanks for the help!
js361
that didn't work....i cannot locate these bolts.....still need help....desperately!
