Removing an OB
Badweed
Hi all,
I am wanting to pull the OB off my 1988 Searay. Its a 135 two horse and a big sucker.
What's the best way to do this. Would you use an engine hoist?
tmcalavy
Re: Removing an OB
Agreed. Using anything less than a powered or hydraulic hoist is dangerous with an outboard that size.
Utahboatnut
Re: Removing an OB
If you do use an engine hoist make sure you have the proper lifting rings for that motor otherwise it can be as dangerous as doing it by hand. just slinging it is not a good way to go as it can do alot of damage and is not balanced right. I'm NOT saying it is the right way to go at all but I removed a 200 horse evinrude by hand with myself and three other friends. It went very well and wasn't that difficult. I had a stand built and in position, with the trailer jack I jacked the boat out from under the engine. Had a few small pieces of plywood under the skeg, once free pulled boat out of the way, then put engine on stand. Went easy just had to keep it from tipping wasn't that hard with three guys. Did the reverse to reinstall after transom rebuild. I think that engine was 385 pounds total but we never actually lifted it up, just kept it balanced for a few minutes. As I said not the reccomended approach but can be done if thought out and have enough mates to lend a hand for 1/2 hour.
Badweed
Re: Removing an OB
Thanks for the posts. I have three friends.
What is the recommended way to build an engine stand?
Thanks again
Steve
jonesg
Re: Removing an OB
Get a used engine hoist from craigslist. got mine for $125 with an engine stand too. I pull my 375lb'er off myself no problem.
tmcalavy
Re: Removing an OB
Search the forum...somewhere on here is a thread with several examples of built-at-home engine stands. I've made 3 or 4 and learned after the 1st to make them mobile by using caster wheels on the bottom.
Utahboatnut
Re: Removing an OB
If you do buy an engine hoist make sure it will lift high enough. Otherwise you need to put it in a truck bed or the like which presents a whole different set of issues. If you need to lengthen the boom it gets tippy quick. A chain hoist and a good solid tree is always a way to go as well. I used a 2x10 for the cross member of my stand which gave me enough room to bolt all 4 holes to the stand for stability, you may also need to add a piece of 1/4 or 3/8" ply to the cross member to get closer to the transom thickness it helps alot. Good luck as mentioned above casters make moving it all very helpful, just use at least two of the locking type.
Signal 20
Re: Removing an OB
I cut a 3" hole in the celling of my garage. Screwed a piece of 2x6 into 2 seperare 2x4 studs in the attick and tied a strap to the 2x6 from an old tie down I had in the garage. I then hung the tie down strap through the hole i cut and I then hung a $30 come along I baught from lowes from the hook in the tie down strap. The come along was more than enough to lift, support and get my O/B onto my homemade engine stand
