Removing Bottom Cowling on 1997 Force by Mercury 75hp
To remove that you have to remove the motor off the lower leg first
Do you know how I would go about that. I’m trying to take the exhaust manifold off.
The exhaust is attached to the bottom of the block. After removing the rear cover below the cowling you can get at bolts holding the motor. There are also bolts around the motor in front.
Don't know which motor you have but here are some pics of my 125 Chrysler
