Removing Exhaust y-pipe/collector
JMSRV190
I have a 1974 mercruiser 302 with an 888 outdrive. I've been slowly getting it working. My last bit to make her seaworthy is, shes taking on water. When shes running she doesnt take on water. But when shes off she does. Upon removal of teh manifolds and risers, I found that it looks like the y-pipe/collector pipe appears to have cracked from poor winterizing. I've looked through my maintenance books and can't find any info on how to remove this. And its difficult to see how it would come out any help?
Bt Doctur
Re: Removing Exhaust y-pipe/collector
after the engine is removed, it unbolts from the transom housing
JMSRV190
you have to remove the engine? or is this just to make it easier?
Don S
Look at what you have, Look at where the bolts are that hold it onto the transom shield. Try to remove the bolts. Even if you could get the bolts out, look at the shape of the pipe and the location. Do you think it's physically possible?????????
JMSRV190
ok thanks for you help fellas at first look it looked like it came apart differently.
muc
"Retired" Association of Marine Technicians...
If I remember right the 888 has a 3 piece Y-pipe.
Might be possible to do it with the engine in the boat.
Don?t get me wrong ---- I?d pull the engine.
But I seem to remember doing flappers with the engine in the boat 25 years ago.
Good Luck Muc
