I've been having trouble with my fuel delivery. The problem is while running 1/2 to full throttle my primer bulb goes flat and can't be pumped back up. What I do to get the primer hard is release the drain valve on my fuel/water separator and I'm the able to run for a little while. So far I've changed the primer bulb, fuel/water separator, some of the fuel line. I've also tried loosening my gas fill cap and blew air through my vent line. I'm now at the anti siphon valve but it's really corroded, any ideas how to free this up, I'm worried about stressing the tank. Also what about removing the 90 degree fitting going into the tank? Is this fitting threaded normally?
