Re: removing lower unit on 77' johnson 85hp
1st. Timer.,<br /><br />It's ALOT easier if you put the engine in reverse first.<br /><br />The shift linakge disconnect is located under the bottom carburetor. Just romove the bolt and the linkage shaft will slide out with the lower unit.<br /><br />It's tedious to get at, just be patient.
