Removing nuts and bolts frozen from saltwater
GasCan II
Hope I put this in the right place. Does anyone have any tricks to remove nuts and bolts that are frozen from saltwater?
Baylinerchuck
It really depends on how bad they are, size, how long they’ve been seized, and location. Heating the nut can help loosen the threads since both metals will expand at different rates. Brake fluid is a pretty good catalyst. Sometimes it’s just best to cut your losses and use a nut splitter, grinder, or sawzall to remove the offending fastener.
Sea Rider
Yep as suggested as long the bolt's head doesn't break inside the crankcase...
Happy Boating
heat
mix of acetone and ATF
prevention of seizing in the first place by coating the bolt threads with permatex #3
Sea Rider
OK applying Permatex 3 to the removed salted bolt, what about all the others ?
Happy Boating
