Captain Jack
- Joined
- Sep 4, 2004
- 11
Can someone give me step by step instructions for removing oil pump and oil sensors on above motor? This engine, as I understand it, has a stainless oil pump drive shaft with a brass hub and nylon gear and is prone to corrosion and oil pump drive gear failure if it sits for any length of time without being run. This makes me nervous as we live in VA and boat sits alot in the winter. I understand the only warning sensor is for oil level in engine mounted oil tank and if shaft drive fails there is no warning! Thanks for any and all advice.
