Removing oil pump drive on a 1992 mariner 150 V6
BTL
Serial # OD177534
Hey guys. I decided to take the oil injection system out of my engine and bought the pump block off kit. But now I can't figure out how I'm supposed to get the drive coupler out of the powerhead so I can install the plug. It doesn't turn and there isn't much to grab ahold of. Can somebody tell me how I get this out? I'm sure it's something simple I'm missing. Thanks.
BTL
The pump drive doesn't move. I assume the gear that is supposed to turn it is stripped.
What happens when you turn that shaft with a screwdiver ?
BTL
Is it supposed to unscrew?
Faztbullet
That is a plastic bushing for the rotation magnet and should just pull out. If its stuck just install a screw in slot and grab it and pull it out. Then you have access to oil drive.
BTL
Thanks, I'll try that.
