They're just little sheet metal hats, screwdriver hammer vice grips are a great combination for destruction, you shouldn't have to torch them off but maybe? You coulkd try splitting them with a little cold chisel.
Are you going to try and reuse them? Just asking as they kind of self destruct when removed,,, though I have been lucky and used them again when they were OK after removal.
I've removed them before by turning them, down pressure on the rod and turn them with a pair of vice-grips, they kind of unscrew,,, even though they don't have threads on them.
A dremel or grinder would take them off quickly, just make sure you don't scratch up the galvanized coating on the rod...
Did get the entire trailer hand sanded this afternoon so there has been some progress.![]()
I bought all new rollers, shafts and pal nuts as I have no intention of reusing the old stuff. I only have one roller that has the pal nuts, and now that I am struggling with this one, I think I'll forgo the pal nuts and install threaded bolts for the shafts. That will eliminate future problems getting the damn things off.
I won't be back at this until tomorrow. Too frustrated today to make further progress. Did get the entire trailer hand sanded this afternoon so there has been some progress.![]()
New shafts, huh...that changes the game!
Sawzall...with a metal cutting blade. Grab the end of the shaft with some Vice Grips (so the shaft doesn't simply spin)...and cut the shaft, between the old roller and the frame.
I would rethink using threaded bolts for the new setup...unless you keep them corrosion free around the nuts, you will be using the Sawzall again...somewhere down the line!
