removing prop
dvrdwn
i have a 1977 55hp johnson and i,m trying to take the prop off. i have the nut and the washer off but the prop still won't come off .i tryed using a block of wood and a hammer.
crxess
Re: removing prop
Soak it real good in PB Blaster. Let it sit for a few hours and try the wood/hammer again.
dvrdwn
Re: removing prop
i gave it a good spray and will try it tomarrow.
thank you!
BAproject
Re: removing prop
Maybe you should try renting a universal gear type puller from Autozone.
Bam, Bam and it's off
dvrdwn
Re: removing prop
the prop goes into the engine so i cant get the arms to grab on anything
