removing rust from inside metal 6 gal tank?
Home Cookin'
I have an old 6 gal OMC tank that hasn't been used for 20 years; looks great on the outside and I want to use it in my old whaler, but the bottom (inside) has a coat of rust. What's the best method to remove it?
Bamaman1
Re: removing rust from inside metal 6 gal tank?
Any rusty fuel tank's not worth the risk of having a problem passed on to your engine.
Either go on EBayMotors.com and find a good used tank or buy a modern plastic fuel tank that'll never have a rust problem.
I have a couple of 12 gallon Moeller plastic tanks for my pontoon boat. They work just fine.
DAN M VAGOS
White vinegar yes household vinegar I'm telling you it works like magic I could not believe how well it works. Just pour it in and shack it up and if you have a lot of rust then add some small nuts and or washers and shack it up then ASAP and I meen ASAP you take it out add diesel to the tank to coat the meatal if not then you will have rust back in minutes.
foodfisher
A pound or two of roofing nails, shaken well.
dingbat
The makers of WD40 make Rust remover soak. Good stuff. Pour it in, drain a little while later and your ready to go. Vinegar will work but presents other problems as noted above. Vinegar is not kind to most plating and protective coatings either
Bob_VT
AND......... always run an external filter if you use that tank!
robert graham
I've used a couple of handfuls of gravel with some water and detergent...then shake, shake, shake, then rinse....gravel acts as a good abrasive to remove rust and scale. But that old steel tank will most likely continue to rust and corrode, so install a canister filter between the tank and the motor( like the Walmart fuel/water separator filter $27) to protect your. Fuel system and motor..
Silvertip
A length of chain dropped into the tank and shaken vigorously works too. Some of the classic car restoration catalogs have a liquid coating that can be applied inside the tank to seal the inside surfaces after being cleaned. This material is used to seal classic car fuel tanks.
matt167
gas tank sealant would work, it's pretty inexpensive too.. x2 using vinegar... Radiator shops could also boil it out but you would need to repaint, and re-decal if you wanted original
colbyt
Master Chief Petty Officer
Never tried the vinegar. I recently tried a trick I learned here or some where else for cleaning a carb using pine-sol 50/50 with water. That made the carb look like new and even removed some rust that was on the welsh plug. After the carb look like new I poured the mix into the tank along with a fresh batch and let it sit for 48 more hours. That carb had crystallized crud every where and had not been stated for 7-8 years.
The hardest part of the job was rinsing all the pine-sol away and getting the tank 100% dry.
Installed the carb with a new filter and the engine started on the 3rd pull.
Sea Rider
Plastic tanks are cheap, the way to go, once metal tanks rusts will keep on going rusting eternaly...
Happy Boating
Home Cookin'
thanks, all. I have a plastic tank but wanted to use this one since it fits the restored look ('64 whaler). And for that reason I hate to install a water seperator but I probably will.
matt167
That's a planned 'mod' for my old Custom Craft too.. Plastic tanks just don't look right in vintage boats hooked to vintage motors..
robert graham
Well if a fuel/water separator will spoil the "antique" looks of your rig, then maybe just a small, in-line fuel filter and mount it out of the way/under the seat or wherever that it won't show....just to filter out any rust/corrosion particles coming from that vintage steel gas tank.
