Removing saltwater seized piston on Mariner 5hp
eddie the boat guy
Is there any way to remove a very seized piston by sacrificing the piston to save the cylinder, I have tried penetrating oil,brake fluid heat and the piston won't move a bit
Honorary Supreme Mariner
If motor was submerged and then left sitting , then crank and bearings will be scrap.----Worth is scrap / parts value.
Chris1956
Stick a brass drift thru the spark plug hole and give it a rap with a 4 pound hammer.
Putting it in a freezer might shrink the piston a bit to help remove it.----But the cylinder will be corroded.----Perhaps distorted as well.-----It may run after all the work.----I think there are better projects available !
heat the cylinder, then use a can of freeze-it on the piston.
another idea, use a hole-saw that is the diameter of the inside ring grooves. you have to be dead-centered on the piston. you saw thru the piston, and the piston comes out in bits, then you can peal the rusted rings from the bores.
flyingscott
If the head comes off of that motor you can try this. Mix ATF and acetone together in a 50/50 mix and fill the cylinder. Let it sit a week pull the head off and find a Hydraulic press and take your chances.
