removing side panels on bayliner classic
sandersps
has anyone taken the interior side panels off of a boat like this. keep in mind that i want to re-install them. 1993 bayliner classic 1950. thanks.
Yacht Dr.
Re: removing side panels on bayliner classic
Hello sander and welcome to Iboats..
Do you mean the Bolsters ? the cushioned pieces in the cockpit ?..
If so .. you should be able to reach up under the side storage to reach nuts to remove ( thats if you have the side storage )..
Or they could be "hooked" in..try to lift up on the side panel.
Got some pics ?
YD.
bear_69cuda
YD is correct,
I had the same boat. " If so .. you should be able to reach up under the side storage to reach nuts to remove " If you look at my Bayliner thread (link below) you can see with the panels out... I also believe there are pics of the panels so so can see exactly where the bolts are positioned.
sandersps
Thanks for the info guys. just didnt want to go in blind and create more work for myself.
