Re: Removing Steering wheel
To remove the Steering Wheel,......
Loosen the Nut,+ back it off to just above Flush with the shaft,....
Sit at it,+ apply Pressure with you knees in the off direction,+ Whack the Nut with a BFHammer....
It'll Pop loose,+ you can remove the Nut,+ wheel......
Then you can get to the screws that hold the helm to the dash,.......
Removing them should allow you to lay the whole thing out of your way......
