I have been rebuilding a 1984 Evinrude 115hp V4. Model E115TLCRD
it seems one problem leads to another and now the tilt trim doesn't work.
It just stopped mid tilt when we finished putting the lower unit back on. Worked fine up till then.
I can hear clicking at the tilt motor but no movement.
I was trying to remove the tilt/trim to take the motor off for testing but I seem to have a problem.
Removed the six bolts, released the hydraulic pressure, unhooked and retracted the tilt ram. I have enough slack in the trim wires.
Got the motor up on the trailer lock.
The shop manual seems to show you just pull the unit out. My unit is loose but seems to be hung up somehow and doesn't just tilt forward and slide out like the shop manual says.
Any ideas? what am I missing?
doug
doug
