jim_in_day
Thread starter- Joined
- Aug 29, 2005
- 175
Help, the service manual has me confused (thats pretty easy to do). The pistons are marked with an L for the loose end of the piston. Ok, I can understand that. However, it says, and I quote "When wrist pin is to be removed, "L" side of piston must be up and arbor pressing tool must be applied to loose side. Always press from loose side to tight side being careful not to distort piston" THAT SEEMS BACKWARDS (sorry if I shouted) But it seems to me that pressing the wrist pin thru the tight side would be more likely to cause distortion than pressing the tight side towards the loose side to get it loose. Then to put wrist pin back in you would press from the loose side to the tight side. What is wrong with my thinking?
