When repacking wheel bearings with grease do you fill the whole hub with grease?
handle Petty Officer 2nd Class Joined May 7, 2012 Messages 104 May 22, 2023 #1 When repacking wheel bearings with grease do you fill the whole hub with grease?
A airshot Admiral Joined Jul 22, 2008 Messages 6,707 May 22, 2023 #2 Not necessary, but don't skimp... but if your using a bearing buddy type system, might as well add as much as you can as it will end up filling it anyway.
Chris51280 Ensign Joined Jan 24, 2018 Messages 933 May 23, 2023 #3 Dexter EZ Lube to about 80% full to give room for expansion. Too full and it will pop out the front seal
